Roger Beep hook up question
  • Thread starter Thread starter MISTAH B35
  • Start date Start date
M
MISTAH B35
Guest
I was given a Workman 3-tone roger beep kit without the instructions, can anyone help me wire it to a Uniden President Grant. It has 6 wires, all of which I tried in different combinations
</p>
</p>
red to 13.8 volts at on off black circut ground
with audio pin or mic gain remove the transmit wire for mic plug solder to tx on beep
wire green wire to where transmit wire was remove the recive wire from ,mic pin wire yellow wire there resolder the recive to rx on beep
