What kind of problem are you having with it?
These power supplies only have a transformer, diode bridge (first device after the transformer), and a filter capacitor, fuse, on/off switch, and indicator light. I got one at a flea market for a buck. Nice little supply for a simple CB.
If it isn't working; check the fuse first.
You must be careful when opening up the box and checking voltages.
Live 110v AC current can kill!
Be sure to unplug the power supply before working on it!!!
Be very careful; or ask a friend who knows to show you how.
Next, make a quick check to see if the capacitor isn't shorted inside (unplug the power supply from the wall).
Unsolder the negative-marked lead on the capacitor and turn the power supply back on and check voltage output - keep your fingers out!
If you see DC voltage out now; then the cap is bad and you should replace it with the same value - about a $1 or less.
It is used to filter out AC hum from your radio!
Next thing to check if the capacitor wasn't at fault - would be the 'diode bridge'.
The diode bridge is marked by 'AC' on two of the posts; that is where the only two wires out of the transformer goes.
On the other side of the transformer is the 110v AC is coming in; just inspect to be sure something has gotten loose.
Check the switch with volt/ohm meter - BE CAREFUL when power is on.
You should see 110-120v AC on this side!
The other two posts on the diode bridge will be the DC output and should be marked on the device as such.
Use a multi-meter and probes to check which side is "+" and which one is "-".
Be very careful when the power is 'on' and the box is open.
Make sure that the "+" goes to the "+" terminal on the back.
A diode brige rated at 2-3 amps should cost about $1-2 or so.
NEVER hook up your radio with the voltage reversed; you will pop the protection diode in the radio and will need to replace it.
Or it could have also done other damage already too - if hooked up incorrectly.
The red wire that goes to your Cobra should be on the "+" of the power supply and the black wire to the "-" ONLY.
