search feature
brandon7861
Loose Wire
I Support WorldwideDX.com!
Nov 28, 2018
2,073
2,281
293
When searching for schematics, some model numbers are too short for the search feature to function. Just as an example, if you search for TRC-458 schematic, no results are returned. I have ran into this problem countless times.
Is there a way to change that? If not, should we be including something longer when we share schematics, like TRC-458_schematic? How do we solve this?
edit: i dont need that schematic, just using it as an example
Reactions: Cable Guy
I use googles crawler to find specifics on this site.
"site:www.worldwidedx.com trc-458 schematic"
The above command (without quotes) will help you when this sites search tool is being a tool.
It's sort-of an Achilles heel of all sites based on software like this. Using google with syntax like "site:worldwidedx.com TRC-458 schematic" will work remarkably well.
