stryker sr 440 help
tallsup
May 20, 2008
29
ok im running a stryker 440,texas star dx 400 and a wilson 1000,on lower channels like 1-15 it breaks up with audio when I run the amp but on the upper channels its fine I have replaced jumpers and the antenna still does it and the swr is 1.1 any help would be great
Mobile or base setup? Either way, it sounds like RF getting back into the radio.
Could be bad cables or a ground problem. Check all your cables and connections
as well as ground from the radio, amp and antenna. Loose connections can do the
same thing.
trucker
