SWR
yes..
but the swr frequency's needs to be designed for whatever vhf and or uhf frequency's you need check the swr's for
Later
Hey..
I never realised Diamond had that...
to cover 900 and 1.2 bands..
will have to pick one up..
Diamond makes good equipment..
Later
KingCobra_CDX882 said:
yes..
say WHAT??
Do you mean that the SWR meter or bridge needs to be able to work at VHF/UHF? I haven't seen many frequencies specifically "designed" for anything.
Beetle said:
say WHAT??
You won't see any specs like that with a Dosy! :wink:
An SWR meter needs to to be designed for the band you want to use it on. There are HF meters, VHF meters, and VHF/UHF meters.
Bird wattmeters can also be used to check SWR by reading the forward and reflected power and using a VSWR Chart. As you know, you need to use the correct slug based on the frequency you are testing.
Master Chief - I was responding to KingCobra's post earlier (yesterday afternoon):
Quote:
yes..
but the swr frequency's needs to be designed for whatever vhf and or uhf frequency's you need check the swr's for \\Endquote.
I'm fully aware of the need for using the correct equipment. That post I quoted seems to say the FREQUENCY has to be designed for the FREQUENCY....
