TR FC-390 question
cphilip
126
Clemson SC
www.cphilip.com
Does anyone know if this frequency counter displays outside the 11 meter range? Specs only list those.
Also will see this same thing with Galaxy name on it.
Does this plug into about any radio that has the accessory socket for a Aux. frequency counter? Is Cobra's plug arrangement the same? in other words... is this plug and receptical a standardized thing?
Specificaly what other plug in FQ's are out there that would work on a Cobra 150GTL?
I got this back from an email to Ranger tech support.
Hello,
The TR-FC390 is designed to work on 10 and 11 meter radios. You can use it
on your Cobra, if it does not plug directly in to the radio, you can have a
CB shop make the necessary adjustments so that the frequency counter will
work with it.
Regards,
Anna Sparks
Ranger Communications
sparksatc84@zoominternet.net
So now I suppose the only question left is if Cobra used the same pin pattern and plug as before. I have heard the thing plugs right into a 148 so one would guess that Cobra did not go out and reinvent the wheel? And so it should plug right in if thats the case. Anyone know?
