Now the meat of the Tram. The channel selector. The channel selector in all Tram D201A's will fail at some point in time. This is because
these selectors were not manufactured with the utmost standards. When the channel selector fails you will notice as your turning the channel selector that some stations will not receive or transmit. Sometimes you have to move the selector between channel numbers to get any response.
There is nothing you can do to repair this control and these are non existent at the present time.
Maycom Manufacturing did a redesign on the crystal board of the Tram D201A utilizing an different channel selector and rewiring which worked
very well but these are no longer available.////
///the channel selector for the D201A, if bad, cannot be replaced. All other parts are available and can be purchased either through your electronic parts store or through Barkett Electronics. Greg Barkett has the largest inventory of Tram & Browning parts available
in the country. Greg Barkett may be reached at: www.goldeneagleradios.com
