TRC 465
The PLL has to be replaced in order to get extra channels. IIRC this radio is very similar to the uniden pc122. I used to have one and it was actually pretty good on SSB, and decent audio on AM. Crank up the rf power pot, through a decent mike on it (you'll have adapt it to the stupid 5 pin DIN) and leave it alone...
Yupp use the N kit they are scarce Ill worn you right offthe bat. I have one in a radio here its a pc-122 same radio. Easy install although Im taking the Nkit out and putting it back in the box because I dont use that 11 meter radio but use to and that radio actually sounded great!! Ive had a few of the TRC-465 aswell there great radios but the LED's in the channel display are notorious for failing.
