Turner + 3
Oldtimer
223
9
78
Stuart Florida
Hi all!!
I am trying to replace the element in the head of my turner plus 3.
I have the head off the stand but how do ya get the element out of the head.
Thanks GOD BLESS
There is a screw under the round metal sticker on the back of the head that threads into a 'cage' that holds the element. Remove the 'sticker', remove the screw, seperate the 2 head pieces then push the element 'cage' out the front of the head.
There is a rubber grommet around the element that is an interference fit into the tapered front of the head. Push the cage/element out the front of the head. When replacing the element push it in through the front of the head as far as you can, then when you tighten the screw it will pull it back into place and seat it in the head.
Be careful about the wires, they will drop down inside the crate easily. Looks like almost all old Turner stand mics has lost the round metal stickers too..
