Uniden Grant XL
Happy_Hamer
Administrator
Staff member
Mar 22, 2001
5,064
215
123
Damnit, back in the day you could jump a few wires here and there and connect them to the switches on the front of the radio and bam you got extra frequencies.
I cannot find that mod, everyone now wants you to reprogram the eprom or buy an expo kit.
I want to convert this thing "the old fashioned way", anyone have a link to the mod?
This will disable the channel 9 function but im sure that you want care about that !
Just remove D28, D29, D30, then on the Grant remove the yellow wire (the one that goes to the channel display) from the junction of these diodes and ground it !
Then add a jump wire between pin 10 of the PLL and the junction that the display wire was just removed from.
Retune if needed
With the channel 9 button in you will be 64 channels above the normal ones !
Channel 1 will be at 27.605 Mhz thrue to channel 40 at 28.045 Mhz !
But DONT use any frequency over 28.000 Mhz as this is amatuer territory !
ground the center of two switches, one switch goes to pin 10, one switch goes to pin 11.
26.815-28.045 with some gaps.
