Weston SV-82 what do I have?
falcondown01
Jul 29, 2010
5
Hi All,
I have come across this handheld Weston model SV-82 VHF transceiver but cannot find any info on it anywhere. Anyone else have some info or a link. I would be much appreciated.
Regards,
Falcondown
You can attach it right here in this thread. When you reply, instead of using the "Quick Reply" box, hit the actual "Reply" button. Above the box where you type your message will be a little paperclip icon that you can use to attach pictures to.
Ahhh..I found it.
Thanks and here is the pic.
I have searched and still can not find anything on this model. Anyone have a recommendation on a possible charger for it (DC volts?)?
Thanks.
Falcondown01
I'd be highly surprised if you find anyone that knows much about that radio. I've seen a total of one in my life and that was on ebay.
I had same walkie talkie before....
It was under brand name STANDARD and it covered full 2m band. AM and FM. It could not transmitt on AM but you can listen Air traffic. I had somewhere even instruction manual for this walkie talkie. Nice thing about it that it had BNC antenna connector, easy to fix, easy to find.
Here is the picture from Radio Museum http://www.radiomuseum.org/r/standard_c_150e.html
