Your vote on Modification
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
Modifications Poll:
How Would you Modify your radio?
1. Would you Crush the Component ?
2. Would you Heat and Extract Component ?
if i had my way i would encourage manufacturers to make full RX/TX mods to be as simple as moving or removing those little black jumper plug thingys
1. Remove the cover from the unit and locate 6 pin jumper labeled J29. Move the shorting block from it's current position to the back/right position as shown.
2. Re-Assemble the unit and check All Bands for Proper operation.
He meant that lame techs are cutting elements from a board, more advanced are using soldering iron :D
Mike
Yup. And this was supposed to be a voting poll damn internetwebz !!!!
Sent from Outerspace, on the DarkSide of X.
i just lift one end.easy to reverse later.why destroy the part?get the wrong one and you are up the creek.
my 78ltw came with talk-back (i asked for it that way) but it was s bit too loud for my liking . after a while i became annoyed with it and was afraid if i tried to de-solder it that id mess something up so i snipped each side of the resistor with toe nail clippers . :whistle:
  • @ nfsus:
    RFactive has left the room.
  • @ Tim Chambers:
  • @ AWP:
