http://shop.wirelessguys.com/s.nl/it.A/id.5819/.fWhat is the best coax for a base. Gonna need about 40 ft.
Thanks
Bobby
That's the best coax right there!
ah, thanks beetle. getting old sucks.Look real close -- you should see a decimal before the 1.
LMR 400 is what I run for everything.What is the best coax for a base. Gonna need about 40 ft.
Thanks
Bobby
tba02, I would caution using Times Microwave LMR 400 UF. Check any reviews you can find on the Internet in this regard if you plan a long run.
My coax supplier stopped handing the UF line due to excessive returns. They claim the rubber cover material (instead of polyethylene) does not tend to hold up well, so they only sell the regular LMR with the more heavy duty polyethylene covering. There is a definite difference in flexibility however.
Something to consider.
Hmmm is that using it outside only it inside as well?
HM, no I don't believe so.
The claim was the rubber covering (not polyethylene) did not hold up well to the sun and weather and I assume that was outside.
Timewise uses PTE covering on their UF coax, and PE on their regular LMR400. I can only assume that PTE is also more flexible than PE.
The differences in specs are linked below.
http://www.timesmicrowave.com/documents/resources/LMR-400-UF.pdf
http://www.rubbercal.com/sheet-rubber/synthetic-rubber/
When I bought my first run of Timewise LMR400 coax I ordered the Ultra-Flex, and that is when I learned of the problem, so I thought I would share the information. Your mileage may vary.
So basically inside or out your screwed. Wow that's not good at all.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
