----- Parts list for 4 transitor amp to be diven by 100-150w pep
PLease refer to Westgate Labs website,or call them,ask for my man Stu..-----
part number --- discription --- quantity --- price
AB-Large --- cabinet --- 1 --- $29.50
HS-Large --- heat sink --- 1 --- $17.50
CB-Large --- c0pper board --- 1 --- $12.95
CF-12V-3-5/8in. --- fan --- 1 --- $2.25
FG-3.5/8in --- fan gaurd --- 1 --- $1.19
2SC2879 --- transistor --- 4 --- $17.50
TIP-120 --- transistor --- 1 --- $0.46
FC-1/4in L-.825in --- ferrite core --- 3 --- $0.44
W-1/2 --- transformer --- 2 --- $2.25
W-1 1/2 --- transformer --- 2 --- $3.10
KRLY2012 --- relay --- 1 --- $3.25
CDM19-500V-910pf --- S/M capacitor --- 1 pack --- $3.25
CDM15-500V-120pf --- S/M capacitor--- 1 pack --- $2.80
CDM15-500V-50pf --- S/M capacitor --- 1 pack --- $2.50
CDK-5KV-100pf --- ceramic doorknob --- 1 --- $10.95
464-1 --- compression trimmer --- 1 --- $2.09
FC-1/2L1/2 --- ferrite core --- 1 --- $0.24
SO-239-T --- connector --- 2 --- $1.45
Now there are other parts needed,,,but,,due to the fact that most of "These"
parts will have a minimun quantity to order,,,I guess maybe go to your
local RatShack and try your luck there...
1/2 watt 10ohm resistor 4
3watt 100 ohm M.O. metaloxide resistor 3
5watt 100 ohm M.O. metaloxide resistor 1
Red LED or what ever color ya like for the on/off indicator
DP/DT mini switch 2
1n4148 diode 2 or a pack (whatever)
1n5400-01/02/03 diode 1
10uf@35v electrolytic 1
4700@35v electrolytic 2
Wire,,,,we will use only "Telfon" wire on this project
14ga and 16ga stranded is what we will use.None of that fake ass high temp
jacket CRAP either,,,If it's not "Teflon" ya dont want it....That simple
It is also "Preffered" that you have some "Teflon" coax,a short peice of
RG-142 or equevelent about 8 in. and a peice of mini "Teflon"
50-ohm about 12in.If ya cant find the "mini" then just use the RG-142,
It's just more difficult to work with,,but it will do fine..
Ok well I'm sure i have forgotten something...lol
I'm sure someone will bring it to my attention...
OK well there's ya a start,,,,I will also be posting a seperate parts list
for the "Bias Board".
In my previous post,,I mentioned jokingly,that this was the "advanced Class".
This means that you will be expected to use a "drillpress" a "Drimmel tool"
and a few other peices of equiptment....SAFELY !!!!
items not mentioned such as screws,taps,nuts and such,,I just figure ya might have
on hand,,if not,,when we get into the build,,i will go over these in more
depth..
Dude!!!! this was more work to put together, than the amp will be to build...lmao
Happy Shopping
Cheer's
rfpowerman 8)
