power input for a KLB-240 power amp
johnxb351
Sep 22, 2015
23
13
13
55
Hi All I have a KLB-240 POWER AMPLIFIER what size amps power supply will i need to run amplifier. Can i run radio and amplifier off the same power supply. thanks
KLB240's have a pair of 2sc2290's, usually draw 16-20a if its not been fiddled with,
I would want a supply capable of 25a continuous or higher for the amplifier & 30a or higher if you want to run rig from same psu.
Reactions: freecell and Tokin
I agree with Bob, 30 amps will work good.
A 50 amp would be a little overkill but in some cases a little overkill is ok.
    AKA- UDX122
