Thought someone might want to check this out
bushwacker
363
4
28
Northern Alberta Canada
1 pill 1446
Switchable class ab/class c
Switchable low pass filter... cutoff at aprox 50mhz
LED power/modulation bar graph display meter made out of 7 leds..... display is adjustable inside the amp.
Rx pre amp
Automatic ssb
Its made to be mounted under a radio.... the size is only 2 3/4 inches high by 5 inches wide and 4 inches deep. The switches on the front are....on/off....pre amp on/off...low pass filter on/off....class ab/class c switch
I thought someone might want to check this out
http://www.flickr.com/photos/27538575@N08/2561760039/
its an led bar graph power/modulation meter....... the driver IC and circuit for it is behind the keying circuit board kinda hidden from view. It works exactly like a led power meter on a cb. It lights up in increments from left to right as you modulate.
The leds light up with increases/decreases in power or modulation just like on a radio.
The first big red led is just power..... from there on its a power bar graph.
I was thinkin of making a quick video of the led bar graph working before the amp is gone..
Hey Switch...... its been awhile. Things are OK for me. Been working on quite a few bigger jobs at work and just havent had the time for cb or surfin the forums. I did read a couple of your posts on another forum... I was going to pm you and say hello.
Hope things are going cool for you as well.... By the way... did you even get the covers off that Palomar to check out what class it is?
no never did Bush , IM totally looking to down grade in the power department here very soon. Cobra XL 450 (4 x 454s) just to much pull on my engine anymore , not so much that ,other then losing half my gas miledge. Seems like DX is picking up and IM just going to go SSB and get something half the size or less.
My gas miledge just means more to me about now. IM sure you can understand. IM just looking for a small AB-1 , 100 watts would be great. Thanks for the reply.
HEY take some more pics. Pics with it running. LOOKS GOOD. GOOD TO HEAR FROM YOU BUSH.
Take Care
BR KEY UP CITY RADIO WAVIN' IT.
Yea sure.... I still haven't got rid of it yet so I can still take some pics and vids..... provided I can pry the camera away from my daughter LOL.
Building a 2 pill class c right now.... same idea... bolts under a radio. The big deal with this one is I want to build it high level modulation.
The rf amp section is built , just have to build a decent audio amp and the rest of the circuit. If I can get the thing to work decently without alot of rf and audio problems it should be a real good modulating amp. Real high swing low carrier possabilites.
But of course... thats if I can get the thing to work... I can forsee some problems but I'm optomistic. I have a few ideas.
Nice to hear from you also Bigred.... thanks for the reply.... hope everything is going good for you.
I added some pics of the class c I'm building now... Its nothing really spectacular.... it might be a little smaller than what everyone else does, but its still nothing fantastic to look at.
Its there is you want to check it out. Just use the links on I posted easlier to check it out.
if you want to see more... heres a video showing how the the bargraph /power meter works.The first couple of seconds is with a higher drive level to show how it displays power and modulation... then I lowered it so you can see it with low drive. I talk kinda slow to try show the bar graph going up in steps. The red light on the left is power.
http://www.youtube.com/watch?v=r5n0jwyeZ6w
