Bypassing driver stage on Texas Star 667V
d1g1man
Feb 25, 2008
50
I have a Texas Star 667V I want to put on 10 meters.
I want to disable the pre-driver (2SC2290) to allow for higher input power.
Has anyone done this? Or know how to do it?
If you are a competent tech, could you check the schematic and get me going in the right direction?
Any help would be greatly appreciated!
Thanks.
You should be able to compare it to a texas star 500 schematic and make the nessasary disconections . Go to cbtricks.com and look at both schematics . Good luck
25-50 Watts PEP/15 Watt carrier (FM)
Thank you everyone for your input so far!
This should not be hard, but if done wrong poof! $$$
Ok
The power input sounds perfect, especially for FM.
Here is the original schematic, and then my butchered version. Feel free to laugh, flame etc.
But what to do with R7 and R10, if anything?
Original:
Extra tasty crispy:
20WPEP into 4X2SC2879's @ 13db. Minimum Gain = 400WPEP Out.
15W in for FM is good.
