Retevis is giving away ANOTHER RA89R Radio for Independence Day! Click Here for more info!
If you don't know what you're doing, the results could be dangerous
There's nothing wrong with grounding the exhaust. In fact, it's fairly common for RFI to be produced by the vibrations of the tail pipe, so people ground them to get it out of the radio's receive. Think of it like a trombone or something. Hams ground the tail pipes all the time, too.
Typical exhaust system is somewhere near a resonant length on the upper end of HF, and it's isolated from ground by gaskets and rubber hanger liners. One of the ONLY things this guy seems to have done right is grounding that exhaust! I usually install at least two bond straps on exhaust systems; one near the front and one near the rear. If it has a lot of extra turns and such, I may add one to the middle. Can't hurt; might help.
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
