If a driver is bad.
Howdy.
If the driver is bad in a Cobra 29 will it rx and not tx.
>> Probably. The driver is on the transmit side in most transceivers. Shouldn't affect receiving at all.
What does the driver do?
>> It boosts a very low-level signal from earlier in the transmitting/modulating chain to a level at which the final amplifier can bring it up to the legal level. Think of an audio pre-amp.
Thanks to all who answers.
>> Zero perspiration.
How does one go about checking a driver
Thanks
One can remove the driver transistor and with information from the data sheet for that paticular device determine which terminals are the base/collector/emitter junctions and usually with a VOM in diode test mode determine if said device has gone short or open circuit.
    boog351 has left the room.
