Installing Echo
dkunesch
Sep 10, 2008
66
My 29LTD classic is finally dead, I am taking the echo board I had installed out to put it in my Uniden PC78LTW. I have 2 brown wires from the board for audio. 1 connects to pin# 2 on the mic connector and the other is soldered directly to the circuit board. Does anyone know where this wire should connect?
The way echo boards work is pretty simple, it's basically "daisy chaining" the echo board in-line with the audio input. The wire that was soldered to pin 2, needs to be wired to the audio pin and the wire from the audio pin needs to be wired to the other brown wire. basically, you are putting the echo board in-line with the audio input of the unit.
Any problems you can email me at Dodgem250@somd.net
BUMP-BUMP!
Dodgem
    boog351 has left the room.
