Talkback is an interesting thing. And getting it right for given radio and tune can certainly be a variable. As well as what kind of microphone your using. Was the radio cap and resistored ? or not ? Does it have a good echo board in it ? or is it just tuned at 100% audio at wherever the power is set ?
There are many variables to conceder and what might work just right for you. Lets say I use a cap/resistored radio (low DK big swing ) that pretty much means audio is off the charts to begin with. Chances are , I would never run a Power mic on this kind of tune , usually NC or stock , for that I'd be right around a 50 to 68 ohm 1/4 watt resistor . ( I use 50s for my own stuff)
I like around a 82 ohm for a diode mod on a 148 (again , that's with stock or NC mic) NC mic's will always stand the cranked out audio on these types of talkbacks , stock mic's leave a little room for feedback ,
These types of tunes on these radios already have off the scale audio to begin with , chances are , if your feedbacking ? Your to loud to begin with or the resistor value is to low or you might even have a grounding problem . (Magmounts and Fiber Glass antenna's beware) could be even worse with a power mic.
for a light type talkback on these radios , I'd go between 70 to 100 with 82 being about the norm for me. But even then , it still can depend on given radio. All in all , what would cause the most problem with any of these radio tunes I mentioned would be a power mic. Just more audio on top of audio. (it's all over the place)
If you wanted to use one (power mic) with talkback , I'd guess to say anywhere between 100 and 150 ohm or so , it can be hit and miss. Now that of course is the cheap mans talkback . They have some pretty dandy variable talkbacks that can save a guy a lot of trouble.
(feedback)
I can sorta dig the feature off an on off switch , but I like talkback , after a while of getting used to it , it kind of has a way of letting you know your OK and set where you want to be. Especially concerning echo boards and or noise toys and recorders (if your into that kind of thing?)
Talkback just isn't for everybody.
