steel tube prices
If these tubes were indeed "steel" tubes they would be a lot cheaper. But I doubt there is much steel in them at all. They are made on ceramic, Aluminum, silver, tungston, and no doubt a host of other rare metals. And there is a brand new 8877 on ebay right now for 550. You just have to know how to shop. Just like I found a 572b exactly the same as the Taylor from RF parts for 39 bucks each.
Rich
Rich
I could never understand why some people (mostly CBer's) call them steel tubes either. :confused1: They are rightfully called external anode ceramic based vacuum tubes. This is because the anode, or plate, is not contained inside the vacuum but rather outside of it to allow for better cooling. The "steel" part of the tube is silver plated copper and nothing more.The copper allows better heat transfer and the silver plating allows a better electrical path as silver is a better conductor than copper and even silver oxide is better than oxidized copper.
Sorry to hear the guy died. He had alot of info. Love the pics of the tubes changeing colors. Some Hams are converting the Ameritrons to these 35s. Cheaper to have the amp moded and get a GS-35B than buy the replacement triode in the first place. I run the smaller GS-31B and they work great also. Just like the guy on the site said. Treat you amps like your wives. One to a house. If you need two tubes you need a bigger one.
The GS-35B isn't happy below the high 3000 volt range under load. A lot of articles leave that out. 3800-4000 should be a design goal.
Non-reinforced turbocharger hose makes a nice chimney for these. All the tOOb's hot air can be routed completely out of the cabinet with a long enough hose. Alpha did that on the 76PA and others.
