And since there is more surface area of the antenna, it really does make you sound "Louder!" Your signal doesn't seem to increase, but your modulation does..
A pole? Why would you need a pole on a mobile? To get it above the roof line? I guess that wouldn't hurt things, just extend the feed line another 18 feet or so, right? Or if it's a really long pole, maybe 18 feet on both sides of that duali antenna set up, that ought'a work, hadn't it? Marconi, sometimes you just ain't 'right', right?
(A pun? What'sa pun?)
So a fatter antenna means louder modulation hey? I guess I'll just forget about the speech processor and save my tube finals a bit and run a dipole antenna made out out of 3 inch wide copper strap instead of 14 gauge wire.![]()
Are people making this shit up, or are they really trying to understand how antennas work and just misinterpreting what they read? I actually mean that as an honest question...it seems that too many are just parroting something they heard from someone else that was misinformed. When will it stop?
Or you could just buy a JoGunn with "audio gain."![]()
