Big Mag Mounts
DJboutit
468
48
I have seen a few times on ebay 5 & 6 mag mount mounts anybody seen any like these & where could I get one
Those are just multiple Tri-Mag mounts that have been put together with bolts and spacers to make larger mounts. The biggest I've seen are four mag mounts. I saw some four mag mounts at Dayton with fairly big screwdriver antennas installed on them. Those weigh a lot more than most CB antennas...what are you trying to install on them?
One 3 Mag holds my preditor 10K 22 inch shaft just fine. I like the small stinger when using Mags. More flex. Peace!
hey look at it this way
he can get 4 more antenna beehive mounts and tie all the mounts intogether and have 5 coily antennas
now that would create some RF for sure
if you can configure the mounts to where the 3 mounts are at the rear
and have 3 antennas standing up the middle antenna stinger will be longer
then the antenna in the middle will be hot which will be 4 to 6 inches shorter
then the other mount will be about 2 to 4 inches shorter
this will give you the rear 3 antennas grounded
shutting off rf from the rear
and shooting it back forward
and with 3 reflectors thats just that much more Rf caught and sent back forward
Now for the BIG difference
you already have 3 times the amount of RF bouncing back forward
now the hot antenna in the middle will reenergize that RF which is now 3 times the amount then direct it forward
and now the front antennna which is the director
will narrow down the beam width of RF to a almost pinpoint direction
i sure dont want to be around that mobile when it keysdown
talk about making your hair standup
or atleast be standing in front of the mobile
better be safer and stand behind it
:scared: Glad he's way down south in Houston, and not up here in the Big D!:crying:
thing is if he goes with that setup
then if he points northeast or north to talk skip you will be hearing him
if he points north or northwest then i will be hearing him
