We don't know if they skipped it or not, but I don't believe they can issue a citation without first requesting that she get the problem fixed and she failed to do so. Then again, most likely the people in the LA office are just too ignorant to know that the provision of Part 15 under which she was cited require she be given the opportunity to fix the problem before being cited.
The above date was when they found where the interference was coming from. Now look at the date of the citation-On August 13, 2009, agents from the Los Angeles Office
investigated the allegation and located the interfering signal
emanating from Ms. Frausto's residence. Further investigation revealed
that the source of the interfering signal was a Philips amplified
television antenna, model Mant300, installed on top of a television
set in the residence.
The citation was written 7 days after they found the source of the interference. It sure doesn't appear they gave her the chance to rectify the problem.CITATION
Released: August 20, 2009
By the District Director, Los Angeles Office, Western Region, Enforcement
Bureau:
Let's look at the citation itself-
It may very well be the reason the citation was delivered, the FCC will now attempt to drag Phillips into a large suit and then fine them and hand down an earth shattering decree that they recall all unit affected and replace them.I hope that this woman has someone who can assist her in this matter with the FCC. I believe that I would be applying some pressure to the suits at Philips for some sort of representation. Then again, the idiots at the field office that filed this absurd citation may just drop the NAL/citation if the device is removed from service and destroyed. Philips would more than likely not want to claim any responsibility since they did not have control over the installation or use of the device. Maybe it is time for Obama to find another FCC Czar.
73, Dave
She did not have a transceiver IE radio station so they had no authority to enter her home.As I said, we don't know what happened. To discover the cause of the interference, she had to let them into the house to inspect the equipment. If they told her to shut it down and stop using it and she said no, or said yes but kept using it then they would issue a citation immediately. I am sure that Verizon is paying big licensing fees and so its complaints garner more attention than your every day citizen. On the other hand, the LA office of the FCC is one of the worst in the country. Dallas is a close second.
Maybe so, but the FCC does not break cobras balls each time one of there radios is seized in a station raid for transmitting more power than is allowed neither should they assume all these devices are faulty such as in the xm/sirius case.The reason FCC is so vigilant in this case is an oscillating TV preamp is a hazard to navigation.
Once they knew the source they could be called on the carpet if someone got killed.
A preamp emitting even a tiny amount of R.F. IS a transmitter.
BS on a hazard to navigation. Maybe if the unit is on the plane and 10 feet from the cockpit, but it is not going to interfere with navigation while being operated in someone's house.
Are you a pilot?
Are you an engineer.
B.S. based on what information.
Please back this up with something of substance.
Based on common sense and based on testimony of FCC engineers. Common sense, we know that cell phones can interfere with planes, but you don't see planes crashing everytime they fly over a cell tower. FCC engineers admitted in the Ranger case that you have to be on the plane to interfere with navigation unless you have about a 1000 watts of power and you are sitting under the flight path. I don't think that the woman's antenna had a 1000 watts of power.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
