mod swing
Tell the "big guns" to get their radios fixed and turn down the amps. Around here we call them gator stations. All mouth and no ears.:lol:
PR
Yep.
Haven't heard that expression used in years.
"Alligator Stations; all mouth and no ears..."
Grandpaclint:
Aren't you using an IMAX antenna and have it ~36 ft off of the ground to the feedpoint of the antenna - out in the desert as I recall? Using decent coax?
I run the same thing, and have talked all over the US, Canada, Alaska, Hawaii (again today as a matter of fact), Mexico, and Brazil (less than a week ago). If it has a good SWR and is up high enough - it should work great for an antenna that cost less than a $100. I surely wouldn't fault those radios either; they should be just fine. You might consider a little amp and matching power supply if you want to be a bit louder. Shouldn't be much of a problem with few people around.
