need a little help Attic Dipole.
sandpiperx
Jan 15, 2010
72
62
Denton, Texas USA
I have a dipole ( inverted v) I have been testing in the attic it stands about 30 feet up, Running off my antenna switch. Running a galaxy dx2527 through a MJF tuner with a SWR at 1.4 The problem I am running into is I am getting voice through on computers through out the house and it keeps making my comp mouse to be reset every time I key this thing up.. Any help or thought would be great.. I am picking up alot of great signal on 11 meter. Filter etc.. I don't know..
Thanks in advace
Attic Dipole
What is your SWR without the tuner?
Do you have a good ground on your station and the tuner?
Running an amp?
Running a RF filter(low Pass)?
Your wireless mouse may be one that uses 27mHz to communicate with the computer.
You may need to place chokes on your speaker wires
Were you getting this interference when the Dipole was Horizontal ?
All the Best
BJ
I will look into that I do Have a balum that was already wired in and the coax connected to the bottom. Should I just wrap the remaining coax to the existing balum? .. I read through the post and thinking on a way to do it.
What is your SWR without the tuner? 1.4
Do you have a good ground on your station and the tuner? yes
Running an amp? no
Running a RF filter(low Pass)?no
Your wireless mouse may be one that uses 27mHz to communicate with the computer. no wireless go figure usb logitech
You may need to place chokes on your speaker wires... please explain?
Were you getting this interference when the Dipole was Horizontal ? first shot only vert.. thanks for the time BJ
All the Best
BJ
__________________
Probably the cause for that RF getting into everything is just over-load. It really doesn't take a lot of power to do that, just being 'near' wiring (primary AC, computer, phone lines, whatever) is one way to cause interference to stuff. Computer speaker systems are notorious for picking up RF, for instance. The quick-n-dirty way of handling that is to just turn'em off. Or, do it the harder way, filter, by-pass, shield it all.
Good luck.
I did take out the tuner .. it was in line on the switcher. I have 2 other Antennas on the switch. My swr dropped a little and it seemed to clear up the mouse issue.. So far so good.. Lets see how it goes.. great info thanx
