Adjustable 102
Lazybones1222
Apr 6, 2005
948
29
28
Tampa Bay Florida
If someone would develop and market an adjustable sleeve for the 102" whip, that would go between the whip and the ball mount to replace the spring, I think you would have something. The whip would then be tuneable, instead of having to play with different size springs and coax lengths.
I think it could be engineered out of allthread, jam nuts and a threaded sleeve. Or has this already been done?
If it has - I want to buy one. <img src=http://users.joplin.com/dutch64804/posticon62.gif ALT=":62">
</p>
I have one I got at a garage sale. It was made out of a piece of stainless steel rod, about 3 feet long, bored down the middle for a stinger and threaded on the other end for a 3/8-24 mount.
It works ok and flexs little less than a standard 102 whip. I wrapped some coax seal around the area where the stinger goes into the rod to keep moisture out.
I seen these online somewhere but who sells em escapes me.
</p>
Re: Re: Adjustable 102
Me me me me, i'm in, i want one as well...........I only need the mount, i just need an email address and shipping cost to the UK which wont be much if just the base.
<img src=http://home.comcast.net/~shockwav/greatbrf.gif ALT=":*cacflg">
26 CDX 757, One of Our Subs - subs757
mobile with RCI2970 Astatic575 Sirio 7/8th @120w back at base Yaesu FT757GX Datong FL3 filter Astatic575 3ele Sirio yagi @130W
More than 2000 people are injured by teapots each year in the UK !</p>
OK thanks 338, ask him if he accepts Paypal also, as that makes the transaction much easier, you can post on here or email me at subs757@msn.com
thanks
</p>
Coax lengths don't adjust SWR.
Reactions: Captain Kilowatt
Coax lengths don't adjust SWR if your radio and antenna are 50 ohms.
It don't adjust SWR, even if there is a mismatch. If changing the coax length helps the SWR, it's because the coax shield is acting as part of the antenna system. If you had a tuner, then coax length matters as it can change the impedance (not SWR) to something the tuner can handle.
Reactions: Groundhog KSS-2012
They do make them. I have two of them, Never did use em. They been on the shelf for awhile.
