M107 seen from space !
GunSlinger338
101
Around Tha Dome
check this out
You can see my M107 from space !!! this is google maps
define "space"
space (sp
s)n.1. a. Mathematics A set of elements or points satisfying specified geometric postulates: non-Euclidean space.
b. The infinite extension of the three-dimensional region in which all matter exists.
2. a. The expanse in which the solar system, stars, and galaxies exist; the universe.
b. The region of this expanse beyond Earth's atmosphere.
3. a. An extent or expanse of a surface or three-dimensional area: Water covered a large space at the end of the valley.
b. A blank or empty area: the spaces between words.
c. An area provided for a particular purpose: a parking space.
4. Reserved or available accommodation on a public transportation vehicle.
5. a. A period or interval of time.
b. A little while: Let's rest for a space.
6. Sufficient freedom from external pressure to develop or explore one's needs, interests, and individuality: "The need for personal space inevitably asserts itself" (Maggie Scarf).
7. Music One of the intervals between the lines of a staff.
8. Printing One of the blank pieces of type or other means used for separating words or characters.
9. One of the intervals during the telegraphic transmission of a message when the key is open or not in contact.
10. Blank sections in printed material or broadcast time available for use by advertisers.
v. spaced, spac·ing, spac·es
v.tr.1. To organize or arrange with spaces between.
2. To separate or keep apart.
3. Slang To stupefy or disorient from or as if from a drug. Often used with out: The antihistamine spaces me out so I can't think clearly.
v.intr. Slang To be or become stupefied or disoriented. Often used with out: I was supposed to meet her, but I spaced out and forgot.
[Middle English, area, from Old French espace, from Latin spatium.]
spac
er
n.
The American Heritage® Dictionary of the English Language, Fourth Edition copyright ©2000 by Houghton Mifflin Company. Updated in 2009. Published by Houghton Mifflin Company. All rights reserved.
space [speɪs]n1. the unlimited three-dimensional expanse in which all material objects are located Related adj spatial
2. an interval of distance or time between two points, objects, or events
3. a blank portion or area
4.a. unoccupied area or room there is no space for a table
b. (in combination) space-saving Related adj spacious
5. (Psychology) freedom to do what a person wishes to for his or her own personal development
6. (Astronomy)a. the region beyond the earth's atmosphere containing the other planets of the solar system, stars, galaxies, etc.; universe
b. (as modifier) a space probe space navigation
7. (Astronomy)a. the region beyond the earth's atmosphere occurring between the celestial bodies of the universe. The density is normally negligible although cosmic rays, meteorites, gas clouds, etc., can occur. It can be divided into cislunar space (between the earth and moon), interplanetary space, interstellar space, and intergalactic space
b. (as modifier) a space station a space simulator
8. a seat or place, as on a train, aircraft, etc.
9. (Communication Arts / Printing, Lithography & Bookbinding) Printinga. a piece of metal, less than type-high, used to separate letters or words in hot-metal printing
b. any of the gaps used to separate letters, words or lines in photocomposition, desktop publishing, etc.
10. (Music / Classical Music) Music any of the gaps between the lines that make up the staff
11. (Mathematics) Maths a collection of unspecified points having properties that obey a specified set of axioms Euclidean space
12. (Electronics & Computer Science / Telecommunications) Also called spacing Telegraphy the period of time that separates complete letters, digits, and other characters in Morse code
vb (tr)1. to place or arrange at intervals or with spaces between
2. to divide into or by spaces to space one's time evenly
3. (Communication Arts / Printing, Lithography & Bookbinding) Printing to separate (letters, words, or lines) by the insertion of spaces[from Old French espace, from Latin spatium]
Collins English Dictionary – Complete and Unabridged © HarperCollins Publishers 1991, 1994, 1998, 2000, 2003
space (sp
s)1. The region of the universe beyond Earth's atmosphere.
The part of this region within the solar system is known as interplanetary space.
The part of this region beyond the solar system but within the Milky Way or within another galaxy is known as interstellar space.
The part of this region between the Milky Way and other galaxies is known as intergalactic space.
2. The familiar three-dimensional region or field of everyday experience.
3. Mathematics A mathematical object, typically a set of sets, that is usually structured to define a range across which variables or other objects (such as a coordinate system) can be defined.
The American Heritage® Science Dictionary Copyright © 2005 by Houghton Mifflin Company. Published by Houghton Mifflin Company. All rights reserved.
A medium like the land, sea, and air within which military activities shall be conducted to achieve US national securityobjectives.Dictionary of Military and Associated Terms. US Department of Defense 2005.
ThesaurusLegend: Synonyms Related Words Antonyms
Noun1.
space - the unlimited expanse in which everything is located; "they tested his ability to locate objects in space"; "the boundless regions of the infinite"infinite
attribute - an abstraction belonging to or characteristic of an entity
location - a point or extent in space
absolute space - physical space independent of what occupies it
phase space - (physics) an ideal space in which the coordinate dimensions represent the variables that are required to describe a system or substance; "a multidimensional phase space"
mathematical space, topological space - (mathematics) any set of points that satisfy a set of postulates of some kind; "assume that the topological space is finite dimensional"
outer space, space - any location outside the Earth's atmosphere; "the astronauts walked in outer space without a tether"; "the first major milestone in space exploration was in 1957, when the USSR's Sputnik 1 orbited the Earth"
aerospace - the atmosphere and outer space considered as a whole
2.space - an empty area (usually bounded in some way between things); "the architect left space in front of the building"; "they stopped at an open space in the jungle"; "the space between his teeth"location - a point or extent in space
compartment - a space into which an area is subdivided
crenel, crenelle - a notch or open space between two merlons in a crenelated battlement
pleural space - the small potential space between the parietal and visceral layers of the pleura
subarachnoid space - a space in the meninges beneath the arachnoid membrane and above the pia mater that contains the cerebrospinal fluid
natural enclosure, enclosure - a naturally enclosed space
expanse - a wide and open space or area as of surface or land or sky
opening, gap - an open or empty space in or between things; "there was a small opening between the trees"; "the explosion made a gap in the wall"
swath - the space created by the swing of a scythe or the cut of a mowing machine
amorphous shape - an ill-defined or arbitrary shape
angle - the space between two lines or planes that intersect; the inclination of one line to another; measured in degrees or radians
vacancy, vacuum, void, emptiness - an empty area or space; "the huge desert voids"; "the emptiness of outer space"; "without their support he'll be ruling in a vacuum"
hole - an unoccupied space
enclosed space, cavity - space that is surrounded by something
pocket - (bowling) the space between the headpin and the pins behind it on the right or left; "the ball hit the pocket and gave him a perfect strike"
3.space - an area reserved for some particular purpose; "the laboratory's floor space"area, country - a particular geographical region of indefinite boundary (usually serving some special purpose or distinguished by its people or culture or geography); "it was a mountainous area"; "Bible country"
air space, airspace - the space in the atmosphere immediately above the earth
crawl space, crawlspace - low space beneath a floor of a building; gives workers access to wiring or plumbing
disc space, disk space - (computer science) the space available on a magnetic disk
flies - (theater) the space over the stage (out of view of the audience) used to store scenery (drop curtains)
paint, key - (basketball) a space (including the foul line) in front of the basket at each end of a basketball court; usually painted a different color from the rest of the court; "he hit a jump shot from the top of the key"; "he dominates play in the paint"
no-parking zone - a space where automobiles are not allowed to park
parking space, parking zone - a space where an automobile can be parked
separation - the space where a division or parting occurs; "he hid in the separation between walls"
seat, place - a space reserved for sitting (as in a theater or on a train or airplane); "he booked their seats in advance"; "he sat in someone else's place"
terreplein - level space where heavy guns can be mounted behind the parapet at the top of a rampart
workspace - space allocated for your work (as in an office)
4.
space - any location outside the Earth's atmosphere; "the astronauts walked in outer space without a tether"; "the first major milestone in space exploration was in 1957, when the USSR's Sputnik 1 orbited the Earth"outer space
infinite, space - the unlimited expanse in which everything is located; "they tested his ability to locate objects in space"; "the boundless regions of the infinite"
interplanetary space - the part of outer space within the solar system
interstellar space - the space between stars
intergalactic space - the space between galaxies; "the Milky Way travels through intergalactic space"
deep space - any region in space outside the solar system
5.space - a blank character used to separate successive words in writing or printing; "he said the space is the most important character in the alphabet"blank
grapheme, graphic symbol, character - a written symbol that is used to represent speech; "the Greek alphabet has 24 characters"
6.space - the interval between two times; "the distance from birth to death"; "it all happened in the space of 10 minutes"distance
interval, time interval - a definite length of time marked off by two instants
7.space - a blank area; "write your name in the space provided"blank space, place
surface area, expanse, area - the extent of a 2-dimensional surface enclosed within a boundary; "the area of a rectangle"; "it was about 500 square feet in area"
margin - the blank space that surrounds the text on a page; "he jotted a note in the margin"
indention, indent, indentation, indenture - the space left between the margin and the start of an indented line
form - a printed document with spaces in which to write; "he filled out his tax form"
8.space - one of the areas between or below or above the lines of a musical staff; "the spaces are the notes F-A-C-E"surface area, expanse, area - the extent of a 2-dimensional surface enclosed within a boundary; "the area of a rectangle"; "it was about 500 square feet in area"
musical notation - (music) notation used by musicians
stave, staff - (music) the system of five horizontal lines on which the musical notes are written
9.space - (printing) a block of type without a raised letter; used for spacing between words or sentencesquad
hair space - (printing) the narrowest of the spaces used to separate words or letters
type - a small metal block bearing a raised character on one end; produces a printed character when inked and pressed on paper; "he dropped a case of type, so they made him pick them up"
printing process, printing - reproduction by applying ink to paper as for publication
Verb1.space - place at intervals; "Space the interviews so that you have some time between the different candidates"lay, place, put, set, position, pose - put into a certain place or abstract location; "Put your things here"; "Set the tray down"; "Set the dogs on the scent of the missing children"; "Place emphasis on a certain point"
The actual elevation has been black out on the bottom of screen shot..... :sneaky2:
I would estimate about 4-500ft. :wink:
The bottom right of the screenshot shows: Eye alt. 165 ft. which means the picture is as if the viewer was looking down at it from 165 feet. That value changes as you zoom in and out of the picture. The altitude that shows on the screen is just the height of ground above sea level that you are looking at. It does not show from what altitude the picture was taken.
I have seen many google earth pictures taken with the aircraft taking the pictures shadow in the final offering.
338 have you tried the Street view option yet? it's way kool.
Who said anything about a satellite ??
But ...
Your right this was most likely taken from the belly of an airplane flying between 15,000 feet and 30,000 feet
At that elevation i would consider the area a rather large "space"
But ...
When one talks about something being seen from space, as in the title of this thread, that pretty much implies either a satellite or the ISS or shuttle since airplanes do not fly in space.
jesus christ would you just give it a break....
for god sakes... folks are so friggin petty.
That's right!! If you are jealous...just say so, don't babble out useless drival. The man has a reason to be proud and show his stuff off, not to be nit-picked to death on where the photo was taken. How about everyone that is doing this show a photo from "space" of YOUR antenna the same way he did?
Its all good , some folks find the need to nick pick everything
That's cool , may be an administrator can change the title to "M107 seen from Goggle Earth"
In the mean time I will continue to post up my radio related posts & pictures, and title them as I see fit for those that enjoy to look at-em
Good Day L1
