JF3MKC, Japan - 1 watt on 20 meters
Ham Radio Nerd
Apr 14, 2002
9,335
2,035
383
More WSPR contacts today. Here's an interesting one I made: JF3MKC in Japan. This was made on 20 meters with 1 watt.
WSPR
I will try WSPR tomorrow maybe I can get to Kentucky..ha ha...30 miles from me...great into JAPAN....
Los Angeles, lucky you have an antenna at 42 feet, I was there once..wild area for us country radio operators....GreyHound Bus Station...
DOCTOR/795
DOCTOR/795
You shouldn't have any problems getting into Japan. Just verify that the PC clock is accurate, compare to an atomic clock and correct if necessary, or synchronize with time.windows.com
WSPR 2.0 is a bit different, there is a TX% slider and a box marked special(don't have the idle box checked, it won't even receive then).
About an hour ago I RX'd a beacon from VK6XT, only 10,000 miles away and it was reported to be 5 watt tx on 40M. I am just using a dipole in the attic that was cut for 20M.
  • @ Catalyst 122:
