Varmint XL 350
jc4950
May 16, 2005
49
63
NJ Trooper
I pick up a Varmint xl 350 from a friend of mine the other day. He told me it was in working order but the tubes might be alittle soft because he hasen't use it in years. When I checked it out it has 1 6kv6a tube driving 2 6je6c tubes. I had many amps in the past but never a Varmint. I thought the varmints used 6LF6 tubes? The only reason I'm asking is because I have about 8 good 6LF6s in my tube collection. Thanks guys Joey 2AT054
I've seen a lot of Varmit (Brewer Labs) Amps but, *I* have *never* seen one with with 6LQ6/6JE6 tubes in it.
Varmit amps were made with the tube sockets mouunted on a PCB, is there a place on that PCB for another tube socket to be soldered in? The extra tube and the larger transformer in the same case steps it up to the next "XL" level.
Can you post pictures of it for your cellphone?
