Here is the New Top One (NTO), a new version of the old AstroPlane. It is to be noted that my NTO is actual installed 4' feet below the top on my 33'8" mast, unlike the GM which is mounted on top of a similar P/U pole at 33'8". This places the GM about 14' feet above the 4' foot tall radiator on the NTO and that is a real disadvantage for this 12' tall antenna vs. 22.5' for the GM.
I think what you will see here will be remarkable and should show you that in testing antennas there is more to making a judgment that is close to correct than just using one or two nearby stations to do your testing, and for sure even if you go to the extent to test using the same mount, coax, and radio.
I sure wish both of these stations were guys listed in my group of stations on my previous test, so I could compare them a little, but let me hear why YOU think we might see such results. Is this just a fluke or could it possibly happen much of the time?
Why is the NTO showing a better signal in this particular test, where the station with the stronger signal and showing an obvious difference, compared to the other station, with less signal, showing the same Sunit signal strength for both antennas.
YouTube - Marconi testing his Gain Master vs. his New Top One
Here is my Signal Report. You'll note the two stations in the video are listed as add-on at the bottom of the report below.
View attachment New Top One vs. Gain Master.pdf
