959 channel mod
just did the two switch mod, one switch works and the other does nothing. did the p5 and the p6.
Did you re-check your work?
Each switch goes between each wire that you've cut (p5, p6)
Switches check OK first?
Proper solder job?
Easiest channel mod to ANY radio I've ever worked on . . .
