Hy-Gain super penetrator ?...
Oatmeal
484
78
West Virginia..
I found one of these old antennas and I was wondering where can I find a manual or instructions with the measurements on it ?.....
Where to look or maybe someone may have a copy they wouldnt mind sharing, would be great....
The one I have here, has 2 bolt holes in the base of the antenna where the radials bolts on...this one also has 4 radials at the bottom and I have 3 short ones for the top not sure if its suppose to have 3 or 4 at the top..
goto cbtricks.com
then click antenna assembly or manuals
then click letter [h] for hygain this will be close to bottom
then find penator 500
they have 3 different years for this antenna not sure which one
you,ll need though
Hy-gain has announced that they will be bringing back the Penetrator 500 5/8ths wl. antenna. They expect to have a sample at Dayton, with actual shipping sometime this summer.
Interesting, Penetrator's are going for over $300+ on ebay, if the new Penetrator is built to the old standards, which it should be, the used market for the 500's are really going to take a dump!:wink:
Are you talking performance, or sales?
The I-10K design is based on the Penetrator. Performance should be close. Sales-wise, the I-10K is $350., while I predict the new Penetrator will be about $250. A lot of people just cannot afford that extra $100.
i doubt very much a lot of people will be willing to pay 250 bucks for a vertical either, as for performance i doubt there is much to choose between the bargain basement 5/8ths and these outrageously priced antennas, only difference will be build quality, and i doubt there's 2-300 bucks difference in that,
but if your daft enough to believe all the hype and have more money than sense then go for it, i'll stick with my cheap sirio antennas that easily get me to every corner of this planet when conditions allow, and if they break, so fuck, i'll buy a new one and still have enough left for a couple ounce of weed, which if i'm honest will make me happier than listening to some retard in italy making donkey noises on 27.555.
Based on a report I read once, that was reputed to be done by an RF Engineer with plenty of antenna experience, the I-10K might narrowly miss being as effective as the New Penetrator, assuming Hy-Gain continues to build it as symmetrical as the original design. Will it make an Sunit or more of a better signal, I can't be sure and doubt it will happen even with a good evaluation.
For me, I don't think I've seen or will see anyone soon prove convincingly and report that the differences in tune and/or tuners for such antennas...designed as monobands of similar design, length, and frequency range will show any marked differences due to these two factors. IMO and within reason, the tune and the tuner make little to no difference in performance as best I can tell. This is based on my own testing the idea. I also think antenna modeling may well prove to us about the same thing.
If anyone has an Eznec5 model showing a notable difference in this regard countering my claim, then please email me your file. I would like to see it, and prove me wrong.
Marconi !!!! edromans@comcast.net
The report I read suggested however, that the trombone tuner used in the I-10K did also tend to produce a significant power lobe below the horizon that was near maximum in magnitude, and that suggested a notable flaw in the tuner design that did not diminish the otherwise desirable gain to be noted, but made it prone to other problems.
I consider symmetry in design and construction to be extremely important to superior antenna responses, while the characteristic is hardly ever consider by most.
symmetry seems to not matter to the high powered over-built cb antennas makers ...... except for mr. coily .
i say dump the hy-gain super penetrator blast from the past .
build a MFJ 4K (beefy sigma 4) and make it durable enough for the UK winds and the US snow/ice .
Well BM, I couldn't of said it better myself. As a matter of fact the Sigma4's design takes impressive moves to make it symmetrical including the very long and gradual use of the long tuner as noted in the function of the bottom 1/4 wave element.
If I could calculate the tapper in this tuner system relative to the radiator and develop a meaningful ratio, I bet it would turn out to be virtually identical to a similar ratio of shield to center in RG8 coax. In fact I understand that math has actually been done and that result determined that the S4 1/4 wave tuner was actually coaxial...and in a tuner it don't get any better than that IMO. The Sigma4 is truly a remarkable antenna.
Even though I might appear to get down on Bob with some of my crazy ideas and questions, and at times maybe even disagree, I firmly believe he might be exactly right regarding his view of this design. I wish I had such a mind's eye view to things.
I can imagine that the collinear aspect in such antennas is critical in many respects, and even the proper tune may truly be necessary to derive the maximum advantage that a collinear can present. In the typical 1/4 wave and end fed 1/2 wave I've found thru testing that tune and match, within reason, made little to no difference in performance. Also like I've said before, I understand this also make no difference in modeling either, but without understand how, I've never modeled such.
Bob's idea that he is steering the angel of maximum radiation may be right on the mark, and since resonance is involved very importantly due to it being collinear...this monster may be like tuning a fine piano.
I have posted the following before, I have never done anything to my Sigma4 except set it up up carefully, just like the instructions indicate. For years I didn't even have the correct manual for my Antenna Specialists version of this fine antenna, but I was never disappointed in the response it provided except when I discovered the gamma match was not positioned midway between its two radial legs. For this is one issue that is very important to resonance and match that I found out by accident. I was looking for a reason, but I found it quite by accident.
Bob, I've figured out that I can use the top three elements from my Wolf .64 GP and increase the length of my S4 by 21" inches total. I'll set that up next time and extend it out as far at that will allow and then re-tune the antenna as necessary for the best match, and try again to duplicate the trend toward your results. This length is not quite enough to get to 30+' feet, but I can get over 29' feet I think.
Good Lord willing, we'll see.
