galvanized ?????
  • Start date Start date
Elastic stop nuts are OK until you need to re-use them.
I just use Loctite. Either the Blue 243 or for a bit more holding power yet still removable the 290 green works well. The reds can be removed but you still may break or strip heads on the softer stuff. I use 262 or 263. The only down side to Loctite is the stuff can be pricey. :scared:
don't know if it makes any difference , but i made a mistake on my first post . the goldish hardware is #8 , not #5 . is the #8 stuff compatible with aluminum and is it acceptable for outdoor use on a antenna ?
thanks 359 . i think any future antenna projects i do will use the #8 fasteners . they're stronger than stainless and didn't gum up and snap when i took them off . the goldish contrast to the silver aluminium looks nicer IMO too :thumbup1:
