fan kit on magnum omegaforce s45hp
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
wheres a good place to hook up the fan? i dont want to tap it inline cause the power wire is a constant. i was thinking on the on off volume switch..... but that is hard to get to i think.... let me know? thanks.
Interesting mod. I believe the radio uses a TX relay. I would wire it to that, so that the fan only comes on in transmit, and I would add some kind of time delay so the fan keeps going for about 30 seconds after you unkey.
Tap into the 12V line going to the radio. Add a switch in the line for on/off. Add a potentiometer in line to vary the speed. 100ohm if you can find one but a 250ohm is more common and will work. A 12V muffin fan running on 14/15 volts (running engine) will run very fast and make too much noise. Slow it down with the pot adjustment.
you could also just power the fan off the vehicles fuse box so that its only on when the vehicles key is in and turned .
Additional cooling fans are a great idea and many times necessary on certain items. High power devices like Export radios and transistor amps may come with heat sinks but we see that they can still run uncomfortably hot and we want to protect the finals.
Easy enough to add say a 4 inch muffin fan to the equation and I do this all the time and have such fans running on my gear now. Problem is that a 12V fan running on a hot power source like a home station power supply that the radio is running on (typically turned up somewhere between 13.8-15 volts) or a running vehicle engine (again operating between 14-15 volts) will make a 12V rated muffin fan run very fast and typically will be very noisy.
Experience shows that you can slow down these simple shaded pole 12VDC fans to around 9.5-10.5 volts and they will run plenty fast enough to do the cooling job and be much quieter, even to making little to no noticeable noise. And the extra cooling is not needed all the time - only when doing extended transmitting.
So it works out to make the fan operation switchable - turn on only when needed. And provide a way to slow the fan down for lower noise making.
On my base I have an extra small-amperage variable power supply that I run the fans on. Simply dial the voltage down with the knob to achieve the desired fan running speed.
Mobile I have added a small toggle switch and a 250ohm pot in line with the fan and turn it on when needed and have the pot set to my desired run speed and it needs no further adjustment. Turn the fan on/off as needed. I also added an LED in line to remind me that the fan was running so I would be sure to notice it and to turn the fan off when no longer needed or getting out of the vehicle.
Good luck
Buy a small fan and a cig lighter adapter wire it up and when needed plug the adapter in simple and easily moved from one vehicle to another. I could get into hard wiring the fan to a specific radio but why not be simple cost efficiant and make reusable in the simple method I have stated :wink:
