6JE6 Tube Question
V8Vega
111
5
28
Phoenix Az.
Is it OK to use 6JE6, 6JE6A, & 6JE6B tubes for the driver in my Thunderbolt 305? I have a good stock of these things & would like to use them instead of my 6LQ6's if possible.
Thanks.
It is okay to use 6JE6, 6JE6A, and 6JE6B in your amp, however the 6JE6 has lower plate dissipation than the 6JE6A and 6JE6B. Meaning, you won't get as much output from the 6JE6, nor can you put as much input drive into a 6JE6. A 6JE6 has 24-25W plate dissipation. If you have 6JE6A's and 6JE6B's, use those. They are rated the same as a 6LQ6/6JE6C, at 30W plate dissipation per tube. 6JE6A's and 6JE6B's are basically just shorter versions of the 6LQ6.
~Cheers~
~Cheers~
Cool! I have lots of A's & B's. Some are pretty tall too.
Thank you.
