what about the length of the top hat? It may have been discussed already but generally is not about 60% of the top hat length considered as electrical length.
NB, is there any real verifiable evidence or links stating that the Old 23 channel Penetrator and its Radio Shack .625 counterpart, also made by Hy-gain, are vertical .64 wavelength antennas? All the evidence that I can find for both, indicates that they are 5/8 wavelength. Or, are you just saying they can be made longer, and thus they are capable of being .64's?
I can't prove it, but I think maybe there might be somewhat of an advantage in these Hy-gain antennas, with their raised radial setup. That is just a guess however. I say this in consideration that this might justify the many reports of superior performance. I hope one day to be able to model the phase inductor idea for my Wolf and the raised radials for the Hy-gain idea, and maybe that'll suggest something, one way or another. Nothing wrong with opinions, I have mine too.
I think you favor the .64, because you have asked me to compare my I-10K at .625 and then do the same at .64 wl...with about 6.5" added to the length. Like I've told you, right now I'm just not up to it. I haven't forgotten the idea however.
I know very little about the performance of the Coily antenna, so I can't make a claim about that one. It may be longer, but I'm not sure. My modeling of the a .64 vs. a .625 shows a very slight advantage for the .625. Here is an overlay and the antennas reports of my .625 vs. .64 using a 5/8 wave model presented in a Cebik report...where I duplicated his efforts to produce the exact same results for his 5/8 wave radiator in the report. I think this can be checked and verified in the thread for the link below.
http://www.worldwidedx.com/attachme...nald-k-reynolds-bobs-question-.64-vs-.625.pdf
well , if you add velocity factor of copper wire or various diameters of tubing aren't these physically 5/8 WL antennas already electrically .64 WL or even slightly longer ?
i know you can make an antenna any length you want then build a matching circuit to get 50 ohms and no reactance but i think an antenna is really what it measures. thats why there called a 1/4 or 1/2 or 5/8 wave. when you measure the old penetrater and find its 6 or 7 inches longer then the new one it makes me think its a .64 especially when thats what it measures
i read the velocity facter of air is .9979 so only about 1/2 inch in 23 feet
yeah marconi that makes me think theres problems with your program because ive seen differences when swiching antennas for me or a friend that were alot more then your models show but then you dont see diferences so i guess its fine and every person just has to find the best antenna for his own station.
i dont think you can make a antenna 18 feet long and call it a 5/8 or 3/4 just because you can match it. i think its what it measures and then you build the match that works. i dont consider the macov58 a 5/8 because its to short so its not 5/8. its not a 1/2 wave iether because its to long so i dont know what you call it, maybe a 5/9 wave but its not a 22 1/2 foot so i dont call it a 5/8. if a antenna measures 64 of a wave legnth then it is 64 and will have the match it needs. it just seems like in some of my reading i have read where some think you change the antenna length number acording to matching system but i dont. i still hope you can try 64 with the i10k to see if it works differently then your model says
A Subaru Outback oil filter also works well for getting the curve bent correctly.![]()
For the Beta match the overall length of 12g copper you'll need is 41".
That includes enough for the loop you'll need to make on each end.
Since you have a Penetrator to measure by, simply attach one end to the very bottom connection coming through the insulator cup, and bring it up and over the radials with the Outback oil filter curve, plus another 3", then bend it across at a 90* for a 1" spacing, then back down to the connection at the base of the radiator.
If you bent & curved it right you should have just enough left to make the loop to reach the hole at the bottom of the radiator.
You might want to get 20' of 12ga just in case you need to practice 2-3 times.
The shunt is most likely what took the brunt of the energy and I'll bet it's toast, so, cut another piece of 12ga copper, 16" long, which will include the 5/8" or so required for the loop on each end.
The length measures 10 5/8", bend to bend.
The top extension is 1 3/8" from the bend to the center of the loop.
The bottom extension is 2 3/4" bend to center of loop.
i think the old one was 40 inches folded in half and went up about 18 inches 1 inch wide and 1 inch away from the tubing. the ground side was 14 inches. it took me a few minutes to search but heres the measurments i found from a couple years ago
i think those were his measurments before you bend the curve into it. didnt they have even two different old versions for before and after 40 channels came out? i wonder if there matchers were a little different toWell NB, I'm not sure the old and new are the same like some have claimed, but your idea doesn't agree with a picture I have with a tape rule beside it. Of course pictures can fool you with perspective. But, I'm only interested in the New SP 500, just in case they are different.
Here it shows the ground side of the matcher wire about 14" and the feed side wire looks about 13.25", with the ground wire itself about 10.5", but I think this is an old Penetrator. I would like the specific measurements for the new SP 500.
I have a bracket from another old HyGain that is only 11.5" long. So, if these brackets are the same length, then the ground wire couldn't be 14" and still fit inside the flanges.
I think Eastside is still waiting to put his new antenna up, so maybe he can help with some good accurate measurement for these two wires.
Thanks anyway.
