Dead Key on the Realistic TRC-458 wont go below 3.5 watts?
mr_fx
Oct 8, 2011
1,536
172
173
Kansas City
For some reason I just can't get the dead key on my TRC-458 to go down below 3.5 watts
I would like to see around 1/2 - 1.5 watts DK
this was a very easy mod on my Cobra 29's
ideas?
Maybe the pot is bad. On any SSB radio AM dead key is a snap with a VR pot turn compared to trying to set it on a Cobra 25/29.
9C1Driver;333526[B said:
]Maybe the pot is bad.[/B] On any SSB radio AM dead key is a snap with a VR pot turn compared to trying to set it on a Cobra 25/29.
I agree with 9C1 ... Sounds like VR8 is defective.
The tuning cans/coils on any radio for the RF output stage are impedance matching. In other words, that is the wrong move. You might get the power down; but all you have accomplished is to throw the impedance/balance off.
The best way to lower the dead key is to put a VR in the pre-driver stage. I cannot recall exactly which v.resistor value is added at what point in that circuit is my problem ATM. "sp5it" - a forum member knows exactly thow it is done, as I cannot recall the exact procedure.
But adjusting the tuning coils for less output is surely the wrong way to do it . . .
MR FX-
Is the mike gain pot (VR6) turned down all the way ?? Since the 458 doesn't have a front panel mike gain control, you have to turn VR6 down all the way when setting the dead key.
- 399
Just to be on the lighter side FX, do you own any radios that work OK? :laugh:
I have had that problem after upgrading the AM power regulator, you can change D26 (5v zener) to a 3v or 3.3v zener, you may even be able to get away with it a little lower. But dont just chop it out or jump it, its there for a reason.
Jim
