Repeater offset help
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
I'm having a problem saving two different repeater into memory on my ic-7000. Lets say I program one freq to mem 1, the offset is .600 and then I go to mem 2 its off set is 1.035 well it doesn't save the off set right ? If I set the offset using oth in the menu both freqs use one.... hard to explain..... the only way I know how to change the offset is by using the vol push button which takes me to display, oth, qs, etc......
Sent from Outerspace, on the DarkSide of X.
Check out page 65 of the manual and set up automatic repeater offset. The default offsets will get you into 99.9% of all repeaters as long as you have the correct PL. ;)
Thank you soo much ! Ill check it out now and report back if it works for the repeaters I'm using 73s
U see 435 uses an offset of 1.035. The others use .600 standard. I just tried auto 1 & 2 with no success
After Lao reading pge 65 the chart is not accurate for 435. Tx is 146.400 while rx is 147.435. I have no problem accesseding it on my 2m yaesu ft.
