Patriot, ground plane add on
My patriot is very similar to the old Big Stick antenna except it is 12' in length it is a 2 piece fiberglass whip. I have just noticed a add on product that you can install 5 six' foot aluminum ground plane radials to it by just clamping it around the metal part on the bottom of the antenna where the U bolts are for installation. Does this really improve the performance of this antenna as they state very large db gains. It is priced around $50.00.
i never had this antenna so im gonna go with what i seen with my a-99
rx= was slightly quieter
tx =out 30 mileplus range maybe a half s-unit better
on the a-99 there wasnt a big difference but there was a slight difference
if money isnt tight maybe worth a try.a better bet would be get 4 102
whips and use that as a groundplane kit tghen you,d have a slightly
longer starduster
