Kick Butt GMRS radio's
I need to get an GMRS station and mobile running. We have nice local repeater nearby that has great coverage. It's pretty busy also.
The Midland GXT785 supports a total of 42 channels - 22 standard FRS/GMRS channels and 20 extra channels. Each standard channel supports 142 privacy codes
What are the "20 extra channels" ?
we have similar radios at work.....the extra channels are just repeats of the regular 22 channels with permanently set "privacy codes".
I am skeptical of the claim of 5watts output, you ought to look up the FCC ID on the back of it and look up their paperwork. The ones we got are the same chassis as the GXT785 but only put out 1.5w. I am curious what these will actually do.
I personally do not care for them, they are flimsy, especially the shell, of thin, brittle plastic. The solder joint of antenna on these breaks real easy too, and a similar issue is the plastic shell of the antenna (hard non flexible plastic), just falls off. Also next to impossible to tape to a shoulder strap because of where the buttons are located, but I doubt any manufacture thinks of this, just some happen to put the buttons where you can tape it better.
On a good note, their audio is good as motorola, the NiMH battery packs are sufficient, i think 1100mAh compared to 300 or whatever the motorolas are, and they take a common microphone/speaker plug like most professional and ham radios.
I like the motorolas better, about 1.25w, one less battery than the midlands, smaller in size, hold up alot better, will display the "privacy code" someone else is using when its scanning the channels, and just feels good in the hand.
And I use these more than anyone, I also talked to another crew 35 miles away from top of a tower up on a mountain, so it is theoretically possible to get advert range. Typically on the ground level more like 2 miles, much less in rugged terrain, sometimes less than 1/4 mile.
It is what it is, a cheap blister pack radio, but for $20 you got a steal on them.
I got a pair of the GXT795vp4 radios last month. It's true that they're cheap and probably fragile, too. But the clarity and range on these little things is surprising. To me, anyway. In a rural area, I was able to talk clearly at a little over 3 miles. In town, they worked well up to a distance of a little more than one mile.
All of these GMRS hand held radios are VHF and 'line-of-sight'. They all have a typical rubber-duck antenna which will further limit their range. They are subject to the same limitations of any HT of the same power output, and that's very limited by the nature of them. The 'possible' range is almost never going to be the 'typical' range. If you consistently get anything near a mile in any sort of built up area, you are doing very good. I certainly wouldn't expect that though, and expecting to get anything like the typical quoted range is really believing in the tooth fairy.
If this sort of radio suits your purpose, then great.
GMRS/FRS is on UHF.
Geratol? Probably not enough coffee. Or Famous Grouse...
(It ain't easy being this perfect! You gotta make a mistake every now and then to maintain a bad reputation. Howz that one?)
