Yup thats the one there i was speaking about
I have a further question, dont know if anyone is versed on it
i calculated a 6db attnator would bring down my 100 watt output to a max of 15 for the amp input, just incase i ever forget to turn the power down.
well after running the math, i would be dissipating well into 70 watts of heat in the resistor and a suitable non wire wound is quite expensive at that wattage.
So, im left with 2 options
No attenuator, turn the thing down and pray for NO smoke
3db attenuator which should help somewhat and maybe give margin error
Or i suppose i could sample the input signal with a detector diode and set it up to trip the swr circuit and turn the amp off on over drive, but i haven't looked into the complexity of this yet.
and upon further investigation i could build a 6d with caddock resistors rather reasonably
