So what your saying is you should pass the LDF4 on to me?
Show me where I said that.
I am actually using the LDF4 now and need to transfer it over to the new tower in the spring when I install the antennas on it. I meant the Belden cable is still on the reels. I need it to make patch cables on each end of the LDF4. In other words, no. I am not sending it to you because then I will be the one looking for cable. have you looked at The Wireman or Ham Radio Outlet? Just google them.
Hello, all. I procured one of these gems from Warren, as well. First thing I am thinking of doing, is changing the output connector to an N. Has anyone done this yet?
Um, the SO239 suggestion was not meant to be taken seriously...
Get yourself a real connector on there instead.
What are your plans for the input connector?
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
