Astatic D104M6B
Does anyone know where you can buy the push to talk switch for the Astatic D104M6B?
Take apart the switch down to every piece like I did and clean every part by hand than file good contacts on the ptt plates and put in new wire solder it back up u should be fine.
Sent from my DROIDX using Tapatalk 2
Thank you for the info. Sounds like it should fix the problem.
Okay Guys I have another question. Have all the D104M6 mics had the switch problem or is it just the newer ones? Is there a way to look at the mic and tell if it will have the problem if not all of them have it? Thanks again for all your responses.
Reactions: Slowmover
  • @ 357:
    holy man no activity or what?
    357 has left the room.
