Yaesu FT-757GX2 help?
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
Got the radio today so far so good fun little radio. CW is amazing on it too!
Here is the CIV control cables that came with it.has 3 RCA jacks 2 headphone type jacks and the box has a RED light & uses RS232 jack which my PCI card should be arriving tomorrow,.. is this a signalink box? looks like it does the same thing...?
The Other wire has a RS232 and a SUBMINI(?) jack similar to what my FTM-350AR uses.
dunno if that is a signa link or not,... but after you get the mini adapter , you should be good to go for any and all digital modes
BUMP.
Can i get some help plugging all these wires into the correct reciprocals
Sent from my DROIDX using Tapatalk 2
BUMP.
well the RCA jacks to to the AF out on the back (plug #17 in the manual) and to plug 20 RF out 50-50 chance of correct connection unless the RCA plugs on the unit are labeled.... just plug and pray you should see the waterfall indicate RX signal
same for the mini din stereo plugs, they go to audio in (or line/mic in) and audio out on the 'puter
I decided after much brainstorming the simple din cable works just fine on digipan it keys the radio transmits like its supposed to. I am seeing 7w output on psk31....
The more complicated cable is put away obviously its not labeled and would rather not risk any damage.
Rca on radio is labeled cables ia not
