Yaesu Update question
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
So this is my radio firmware and panel..... and ill post the update program ...am I do for an update?
my radios firmware and panel firmware..(?)
Program from yaesu
The version you have (1.6) is newer than the one they have available for download (1.3). I wish I could get the one you have!
Good to know. Both of my ftm-350ar's have 1.6
help me find a way to use vb7 or whatever yaesu uses and ill hack the radio's firmware and rip a copy of it send the same version to you.l
Sent from my DROIDX using Tapatalk 2
Before applying anything higher than 1.3 to your radio, I would contact Yaesu. When I asked them via email about the newer version, I was lead to believe that it was not compatible with older boards.
Brian
N5BRJ
Thanks both rigs were made in 2012
I ran into the same issue, my FTM-350AR came with version 1.5 I was told how ever that the panel version 1.1 needed to be updated... After the update I was at version 1.3, and still at pannel version 1.1.. Not happy after that at all.
do you notice any diferences between the 1.3 and the 1.6?
I wouldn't know as my radios are up to date since I purchased them.
Faulty Firmware 1.6
My 350RE has firmware 1.6 apart from a few minor bugs it worked great.
However, after a violent thunderstorm everything went pear shaped and it began behaving badly, mere coincidence or what I don't know.
Now my FTM-350RE has been consigned to storage as I can't get a 1.6 firmware update to correct the problem, nor can I get any response from Yaesu globally to my e-mails. Just ordered a new Kenwood TM-D710E, at least it will work until the filters die, and I can repair that myself.
73 all - Gerry.
Update: Thanks to Sam, Yaesu UK, I finally got my hands on the elusive 1.6 update, installed and problems sorted.
Yaesu Comments: Hi Gerry
Please see attached zipped file.
1.3 is OK to use.
As far as I am aware 1.6 is for European use only.
This may be the reason it is not on US website, I will check.
I uploaded the file here: http://groups.yahoo.com/group/ftm-350/files/
73 Gerry.
Gerry,
Have you thought that maybe that thunderstorm was the problem, not the up-date? There are a few things that just can't be cured with an up-date.
Gerry,
Exactly and I agree. To the OP can you give us some details on the problem ??
Gerry,
Hi Doc & Vanilla Sky, the jury's still out on that one, however I'm inclined to lean towards the effects of the thunderstorm as lightening struck the QTH and all the trips when off causing a power outage. The 350 was not connected to an external antenna but a WonderWand multi bander, it was working perfectly prior to the storm and when switched on again it took an unusually long time to display.
The SET menu options did not work, no TX, memories wiped, and eventually the display froze. I should point out my rig came with version 1.6 (exp) factory installed, I wasn't updating. But it seems that version 1.3 and 1.6 are actually compatible, possibly having minor differences, see Yaesu comments in previous post update. Anyway, installing the update cured the problem I'm glad to say!
73 Gerry.
I think it would be safe to say that the near-by lightning strike/surge 'got to' your radio. I think it's also safe to say that if all it did was scramble it's memory, then you are very lucky!
If it 'popped' the 'breakers', then there was a surge in your house wiring until those breakers 'broke', which is 'normal'. The antenna that radio was connected to isn't the only source of 'surge' that can affect the radio, the power lines/mains are another source. As you found out. All things considered, would you buy me a lotto ticket?? If I win, I'll be happy to reimburse your costs... :)
Firmware Update 1.6 (EXP)
Got an email from Sam Yaesu UK below......
You should not have uploaded the update to Yahoo Group.
Software should only be available from our official website.
I know you believed what you were doing was correct but please do not do
something like this again.
We have had problems with people downloading incorrect software to their
radios.
Regards
Sam
I have removed the file from Yahoo Group so anyone who needs it will have to contact Yaesu directly until such times as they post it on their website!
73 Gerry.
radios.
Regards
Sam
73 Gerry.
So... Is there newer update for my FTM350AR?
Again my numbers on display read:
VERSION
MAIN:1.6
PANEL:1.1
