RX75 Pros and Cons ? ? ?
curlyjo
Supporting Member
Nov 13, 2009
169
39
Southern Calidornia
I would like to know all about the RX75. What are they good for? What upgrades need to be done to the radio to make them work right? Do they spatter? What radios match well with them. The proper use of them. ETC. ETC. ETC. Thanks for looking ! ! !
For the cost of putting one of those POS on a radio you can buy a cheap 150 watt amp.
Do a search.
The RFX-75 can be great for the driver who cannot run an amplifier but wants more then 30-40 watts. Some drivers cannot even run Export radio's anymore either. You can get a Cobra 29 with an RFX new for under 200 bucks. This will give you right at 100 peak watts.
Some new radio's also come with the RFX-75 already installed suck as the Magnum Raptor, 257HP, and Omegaforce HP. They seem to do ok as well.
As already pointed out, unless necessary an external amp is always the way to go. That or get a bigger radio like the 2970N2 or Galaxy 98-VHP.
