if the antenna is connected to earth ground doesn't that defeat any effort to isolate it from the mast ?
Not if you choke both the coax, and the ground wire (if needed) using a small in-line series choke coil to block AC/RF.
when i talked to CEBIK he told me that radial angle makes little practical difference to radiation angle until we fold the radials up towards the vertical, his upper hf monopole article seems to agree with what he told me,
all those models show the antena connectd to a conductive mast, what happens when the mast is isolated?
only the 90 degree radial model has the little circle i thought you said indicated the mast was grounded?
mm2000's spiderplanes are horizontal as you describe from the pics,
the others were sloping not by choice but convenience of what we had laying around,
( how can we reduce the rf on the mast/coax without buying materials for radials/isolator/balun)
what did CEBIK say would happen if you "fold the radials up towards the vertical" ?
eddie,
i see an advantage with isolation, certainly in the potential for rfi from mast/coax,
garry happens to have his imax on 40ft of crankup mast while other folk used different length masts,
i think it would be easier to digest if you always put the green curser on the usefull lowest lobe for direct comparison,
max slice gain can take care of cloud warming duty's.
i had no idea a ground wire could be choked so that it didn't act as a ground element . how is it done ? is it made the same way and size as a air core coax choke ? is the size of the coil frequency dependent ? or does one size fit all ?
Eddie it may be my machine but it says documents damaged and could not open it.
booty,
i posted what mr Cebik said about folding the radial up in the sigma4 alternative viewpoint post,
http://www.worldwidedx.com/cb-antennas/31799-avanti-sigma4-alternative-view-point.html
??? said:booty,
its about time you stopped messing with those groundplanes, make them work for a living contributing to radiation in a favourable way, its like trying to build a model-t when you could be building a vette,
eddie you could have picked one of tom's lucky mast lengths.
Thanks, but which document, I've posted several.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
