Larsen Antenna retailer?
Not much luck with HRO?? They carry pretty much the full Larsen line. With Larsen you can pick the individual pieces, the base, mount, loading coil, and whip and pretty much build your own antenna.
http://www.hamradio.com/search.cfm?ob=MN
Hmmmm.....I can't seem to link to the HRO page with all the Larsen products. Just take another look at the homepage and select Larsen in the drop down field for Manufacturers and look at all the Larsen products.
Thanks guys. I'll take a look again at hro hardest part is finding a 420-450mhz 5/8 antenna.
Ill post up if I have any issues. Maybe I can ring up HRO and ax if they have what I need.
Sent from my Xoom using Tapatalk 2
Here is a long shot for you,try a local commercial radio shop.
I got mine through a guy that is 99% of the work he does,police ..fire.. the guy I found actually had a pretty good selection on hand,with mounts and coax
Here's the AES price pages for Larsen: AES Price list
NMO150B: VHF only
NMO440C: Uhf only
NMO2/70B: Dual Band
Does the NMO440C cover 420-450MHZ?
i have noticed the NMO440B (black) was replaced by the C model. i am trying to get both Antennas without "coils"...or "Closed Coils"...SO if i do hit something the coil doesn't shatter
No coils or springs? They both have coils; it's required for operation. Neither of these antennas use springs. The difference between the B and the C: B = Blackened Chrome, C = Plain Stainless Steel Whip.
Its too bad the black 440 is discontinued.
Sorry I ment coils on the whip !
